BGP on CISCo 2801
Feb 7th, 2007
hello, I need to run BGP on CISCO 2801, and have currently IOS 2801 Software (C2801-ADVSECURITYK9-M), Version 12.4(3f) installed. It doesn't seems to support BGP. Which feature sett do i need?
dgahm Wed, 02/07/2007 - 17:46
I just logged into a 2821 running BGP and it has IOS C2800NM-ENTSERVICESK9-M), Version 12.4(10)
c2800nm-entservicesk9-mz.124-10.bin
Please rate helpful posts.
aceadmin Thu, 02/08/2007 - 07:00
Advanced Security images started carrying BGP in 12.4.9T I believe. Check the Feature Navigator to be sure.
Brian
royalblues Thu, 02/08/2007 - 09:21
Friend,
unfortunately the 12.4(3f) does not support BGP with advance security feature.
I suggest to any 12.4T train image or better upgrade to advance IP services image
HTH, rate if it does
Narayan
