CME with SDM
Feb 7th, 2007
Hi All,
after new callmanager express configuration, I noticed that end users are able to connect to some of the web pages and some of the pages that have HTTPS, the users are not able to connect to them. do I need to add "#ip http secure-server" on the configuration? any suggestion would be appreciated.
thanks
Alex
thomas.chen Tue, 02/13/2007 - 14:20
Yes it's compulsory to add the command " ip http secure -server. When enabling the secure HTTP server, you should always disable the standard HTTP server to prevent unsecured connections to the same services. Disable the standard HTTP server using the no ip http server command in global configuration mode (this step is precautionary; typically, the HTTP server is disabled by default).
