communication betn same sec levels
Collin Clark Thu, 02/08/2007 - 10:12
I am unfamiliar with the FWSM but in PIX/ASA you can use the following command.
same-security-traffic permit inter-interface
daviddtran Thu, 02/08/2007 - 11:30
what you said is true only for version 7.2(1) or
higher. If your version on the Pix/ASA is not
7.2(1) or higher, this will only work for
IPSec traffic.
in FWSM, version 3.1(3) does not have this
feature because FWSM code is always behind
pix/ASA code.
Jon Marshall Thu, 02/08/2007 - 22:45
Actually the FWSM v2.3 supports this commmand as does 3.1. From one of our FWSM's
SZ-JFH-F00-DTE-FW1/dev-ct# conf t
SZ-JFH-F00-DTE-FW1/dev-ct(config)# same ?
Usage: [no] same-security-traffic permit inter-interface
[no] same-security-traffic permit intra-interface
show same-security-traffic
SZ-JFH-F00-DTE-FW1/dev-ct(config)# sh ver
FWSM Firewall Version 2.3(2)
FWSM Device Manager Version 4.1(1)
Compiled on Wed 06-Apr-05 13:08 by dalecki
SZ-JFH-F00-DTE-FW1 up 37 days 16 hours
Configuration last modified by enable_15 at 06:34:12 Feb 09 2007
Whilst it's generally true that FWSM v2.x equates to Pix v6.x and FWSM v3.x equates to v7.x the FWSM code is not just a replica of the pix equivalent.
Jon
