OSPF on simple home setup
Feb 7th, 2007
Hi mates :)
I'll appreciate your help on the setup;
Please see the OSPF1.jpg drawing which shows setup of active devices and PCs.
What I want is, all 6 PCs to ping each other
OSPF will be the routing protocol
questions:
1. would that setup work with the assigned IP addresses on shown setup?
Pls pay attention, serial ports on router arent used, ethernet ports are used as L3 ports, would that cause any trouble?
Tx in advance for helping :)
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 02/08/2007 - 02:29
Could you have another look at your jpg. You seem to be using 40.40.40.1 at least twice and some of the other addressing seems a bit amiss (PC1 & PC2 for example).
There will be no problem using the ethernet ports.
Have you already done a config for your layer 3 devices. If so could you include these as well.
Jon
ohalnet53 Fri, 02/09/2007 - 07:00
hi John and tx for reply.
I am gonna draw new figure with IP addresses and put in to a new topic. tx for your answer on ethernet ports. :)
