3745 NBAR
Answered Question
Feb 8th, 2007
Hello!
Please tell me - what is requirments for running NBAR on 3745 router. IOS version? Memory? And what software i need to install to run NBAR on 3745? (one thing i have understood is that i need to install pdlm file for every type of protocol)
Thnx in advance!
Correct Answer by spremkumar about 9 years 7 months ago
You need to have the required ios code in your router to have NBAR enabled in your router.
Also make sure you have enough memory and flash space available to run the new ios code.
Other than that you dont require any special software to run NBAR..
Bur of course if you need more matching option to be available for you then do install PDLM files accordingly as per your requirement..
regds
Overall Rating: 5 (1 ratings)
Correct Answer
spremkumar Thu, 02/08/2007 - 02:41
regds
