7301 & PXF - Is the architecture the same as 7304?
Feb 8th, 2007
I have found docs detailing pxf supported features on the 7304 but cannot see any reference to the 7301, or any mention in the 7301 docs of PXF or any other processing architecture - does it process switch everything?
thomas.chen Wed, 02/14/2007 - 06:20
The Cisco 7301 router provides application-specific features for broadband subscriber aggregation and network application services with high processing performance.
Each Cisco 7301 router consists of the following features:
Small form-factor?One rack-unit (RU) high with stacking capability:
1.73 in. x 17.3 in. x 13.87 in. (4.39 cm x 43.9 cm x 35.23 cm). The weight is approximately 10.5 lbs (4.76) kg).
?Three native Gigabit Ethernet interfaces?six ports:
?Three optical fiber Gigabit Ethernet (1000 Mbps) ports that use a small form factor pluggable (SFP) Gigabit Interface Converters (GBICs) with LC connectors
?Three Gigabit Ethernet (10/100/1000 Mbps) ports with RJ-45 connectors (Any three ports are available at any one time)
?Both 25-MHz and 50-MHz port adapter operation
?A 64- or 128-MB CompactFlash Disk
?Two SFP GBIC modules: SX and LH options
Power supplies:
Single or dual AC power supplies
?Single 24V DC power supply
?Dual 48V DC power supply
?BCM 1250 microprocessor that operates at an internal clock speed of 700 MHz
?512-KB Boot ROM
?32-MB Boot Flash
Three SDRAM memory options: 256 MB, 512 MB, and 1 GB
?Auxiliary port
?Console port
?Online insertion and removal (OIR)?Allows you to add, replace, or remove port adapters with minimal interruption of the system
?Environmental monitoring and reporting functions?Allow you to maintain normal system operation by resolving adverse environmental conditions prior to loss of operation
?Downloadable software?Allows you to load new images into Flash memory remotely, without having to physically access the router, for fast, reliable upgrades
Front-to-back airflow?Allows you to mount the router from either front or back into 19-inch two-post racks and 21-23 inch four-post racks
