/26 subnet
Feb 8th, 2007
HI,
Can i use a /26 network and assign two subnets of /27 mask from that?
I meant for example from a 10.69.202.192/26, can i take 10.69.202.192/27 and 10.69.292.224/27?
Appreciate your response.
Navneet
burleyman Thu, 02/08/2007 - 05:11
I think you made a typo...10.69.292.224/27....it should be 10.69.202.224/27.
Yes you can do that...
10.69.202.192/26 has the following true...
10.69.202.192 is the netowrk address
10.69.202.255 is the broadcast address
10.69.202.192/27 has the following true...
10.69.202.223 is the broadcast address
10.69.202.224/27 has the following true...
10.69.202.224 is the netowrk address
No overlap and they fit in 10.69.202.192/26
Hope that helps. Rate if it does.
Mike
