verifiy user's SSID whithout L2 authentication
Feb 8th, 2007
I use a cisco 4404 & ACS 4.1
I've no L2 security. I use an external Web auth page.
My question is the following:
How to verify the SSId that the user use to login WITHOUT L2 security (802.1X)?
I've set the allow AAA overide for each SSID.
I've tried [009\001] cisco-av-pair, no success
I've tried the Non-Ip based Nar -> no success because I think that we need first an EAP auth...
Is there a solution to securize with wifi network?
smahbub Wed, 02/14/2007 - 06:46
SSID which the client uses can be checked from the client software.If it is a cisco software you could use ACM or ACM.
Trending Topics - Security & Network
