Configuring an E1 Connection
Feb 8th, 2007
I need to configure an E1 connection. What all do i need to configure on the router?
I have a spare controller card E1 4/3 free on the router. Can this E1 link terminate on a Serial 0/0 interface(V.35) on the other end?
Also please let me know what cabling i would be using with any connectors if required.
Appreciate your help in this.
Navneet
Overall Rating: 5 (1 ratings)
navneet_78 Thu, 02/08/2007 - 05:19
Would really appreciate if someone would help me out on this.
Cheers
Navneet
albert.remo Fri, 02/09/2007 - 02:18
Hi!
Is the other router on the remote site? If so, you'll have a provider for the link that would give you an E1 termination on the local site and a serial termination to the remote site. Yes this will be possible yet you will need some CSU/DSU that I believe will be given by the provider.
On your controller E1, just configure a channel group that would include several timeslots.
Router1
controller E1 4/3
channel-group 1 timeslots 1-2
interface Serial4/3:1
ip address 12.12.12.1 255.255.255.252
no ip directed-broadcast
Router2
interface Serial4/3:2
ip address 12.12.12.2 255.255.255.252
This will create a channel of 128Kbps. The rate of the serial link at the other end should be the same.
Hope this helps, please rate if found helpful
Albert
navneet_78 Fri, 02/09/2007 - 23:37
Hi Albert,
Thanx for the reply.
here, when we are cnfiguring a Channel group and specifying the timeslots, is that a Time division Multiplexing or for an Unchannelised E1?
Also, Iam a bit confused about how we configure each serial interface in that slot. I mean how does the numbering of the interface start if i need to configure a single Interface for the controller 4/3. Will that be serial4/3:0??
Appreciate your reply.
Cheers
Navneet
smothuku Sat, 02/10/2007 - 00:09
Hi ,
Router(config-controller)# channel-group channel-group-no timeslots timeslot-list [speed [48|56|64]]
The value of channel-group-no is from 0 through 23 for T1 and from 0 through 30 for E1.
The value of timeslot-list is a single number, numbers separated by commas, or a pair of numbers separated by a hyphen to indicate a range of time slots. The valid range is from 1 through 24 for T1. For E1, the range is from 1 through 31.
The optional speed setting defaults to 56 kbps for T1 and 64 kbps for E1.
Router(config)# interface serial slot/port:channel-group
Enter interface configuration mode for a serial interface that you specify by slot and port. The :channel-group portion of the command is only required for channelized T1 or E1 interfaces; its value is always 0 for Multiflex VWIC support.
Example:
E1 contains 32 channels which supports 2Mbps and if you want to use or allocate 2Mbps bandwidth to a single serial intaerface you need to specify the following command.
controller E1 1/0
channel-group 0 timeslots 1-31
in the above case you can see only one serial interface and 2Mbps is the max.bandwidth supported by serial interface.
Case2 : if you want to use 30 serial interfaces , each one has 64kbps capacity , you need to specify the following command
controller E1 1/0
channel-group 0 timeslost 1
channel-group 1 timeslot 2
channel-group 29 timeslot 30.
channel-group 30 timeslot 31.
In the above case you can use 30 serial lines for connecting 32 branches.
Hope it helps you.
satish
navneet_78 Sun, 02/11/2007 - 04:07
Hi Satish,
You really made it sound simple. Thanx for the detailed explanation.
Cheers :))
Navneet
