error about license of cisco vms
Feb 8th, 2007
Hi all,
I use Cisco VMS 2.1 and update to Cisco VMS 2.3 to manage IDSM (version 5) but now I see an error.
I have a license of Cisco VMS 2.1 and when I update to Cisco VMS 2.3, I use the same license file but I see the error in Cisco VMS "Error about license" and I browser to directory (contained License of VMS), VMS informed corrupted license file. After I restart Server of VMS many times, I can connect to Cisco VMS.
I don't know the cause. If you know, please answer me early.
Overall Rating: 4 (1 ratings)
tsteger1 Thu, 02/08/2007 - 15:42
Hi Vo Khang,
I think you should open a case with TAC as it sounds like you have multiple problems with this VMS install.
They can also help you with the license file, with the version and help you decide whether to spend any more time on this or start over.
Good Luck!
Tom
mylove142 Thu, 02/08/2007 - 20:05
Thank you , but I can't open TAC because I don't have an account of Cisco. I only have an error after I update Cisco VMS from 2.1 to 2.3. I don't know that is error about license or my VMS server has error.
rhermes Fri, 02/09/2007 - 09:53
I had a similar problem and was able to fix it by removing the pointer to the license file under Server Configuration and then re-adding it.
