Generate inventory reports on LMS 2.6
Answered Question
Feb 8th, 2007
is it possible to get reports every 3 month which gives me all hardware with serial number and all software with versions. If possible i need also a report which gives me the difference to the last report, so i can see, what is new and what is not more available. Is it possible to get such a report out of the box, or must i write scripts which generate such a report.
Correct Answer by Joe Clarke about 9 years 7 months ago
Custom reports are created in the browser under RME > Reports > Custom Report Templates. The reports can then be run via the web or from CLI using the "cwcli invreport" command. Consult the context-sensitive online help within the RME Custom Reports pages for more details.
The Change Audit reports can also be run through the web from RME > Reports > Report Generator.
Overall Rating: 5 (2 ratings)
Joe Clarke Thu, 02/08/2007 - 11:13
You can build an inventory custom report that can run every three months, and show you serial numbers and software versions. For example, the following custom report template ruleset should work for you:
Chassis:Chassis Serial Number:equals:All
AND:Image:Image Version:equals:All
As for changes, you can use the Change Audit reports to get a list of changes to your inventory.
b.hofmann Thu, 02/08/2007 - 23:10
Thank you for the information, but where can i do this. Must i write a script, or is it possible to do this in the browser? Is there a document available where i can find this informations?
Correct Answer
Joe Clarke Thu, 02/08/2007 - 23:36
