redistribution
Feb 8th, 2007
Hi all, If I wanted to redistribute eigrp 100 into 200 and vice versa, Do I need to set any metrics ?
Jon Marshall Thu, 02/08/2007 - 07:04
Hi Carl
You don't need to set metrics if you are redistributing between eigrp processes. You set metrics when the routing protocols you are redistributing between use different metrics eg RIP - hop count, OSPF - cost etc.
Jon
carl_townshend Fri, 02/09/2007 - 01:48
Thanks, So when I redistribute one in to the other, Will they both know about all routes in each others AS ?
Jon Marshall Fri, 02/09/2007 - 02:41
Hi Carl
Yes they will if you redistribute both ways. You need to be careful when doing mutual redistribution between routing protocols.
Here's a link covering routing protocol redistribution. Have a look at example 3 in the Problems section which cover redistributing between EIGRP processes.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009487e.shtml
Jon
