Disable vad on 7912 cisco phone
gogasca Thu, 02/08/2007 - 09:41
Hi Philippe
Please refer to the followling description and the URL for the document,
VAD configuration can be configured through the 'audiomode' parameter:
# Parameter: AudioMode
# Type: bitmap value
# Description: Used for controlling or fine-tuning certain audio features #
# Options: Bit Values
# 0 Silence Suppression in G.711
# 0 = Disable silent suppression in G.711
# *1 = Enable silence suppression in G.711
# 1-3 RESERVED. Must be set to 0.
# 4-5 DTMF Transmission Method
# 0 = Always inband
# *1 = Negotiated via SDP
# 2 = Always out-of-band
# 6-31 RESERVED. Must be set to 0.
# Defaults are marked with *.
AudioMode:0x00000011
See also:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/ipp79
05g/addprot/sip/7905sch8.htm#wp1075121
I hope this can answer your question.
Thank you for your answer, but it did not fix my phone trouble. In fact, i have to disable voice detection in order to always let the voice pass through the phone.
At the moment, when i call an extension with my sip 7912 phone and the called person has answered, i do not hear his voice. I have to talk in my 7912 phone to establish the communication, and then everything goes nice.
So, i would like to shutdown voice detection or change the voice detection threshold.
regards.
Philippe.
Paolo Bevilacqua Fri, 02/09/2007 - 07:01
The info (excellent as always) provided by gogasca indeed it is telling you how to disable VAD by the use of a configration file. You will a small package on (available to CCO registered users) that contains an utility used to generate the binary config, a tagging file needed by the same. Also incuded, bmp to logo utility.
Hi all, and thank you for you help.
I found the soluce by making changes to my configuration file. I post it here so that it can help someone else ;-)
----- cut here -----
#txt
UIPassword:
upgradecode:3,0x601,0x0400,0x0100,,69,,
dhcp:1
Proxy:
UID:
PWD:
LoginID:
UseLoginID:1
SIPPort:5060
SIPRegInterval:3600
SIPRegOn:1
AudioMode:0x00000010
NumTxFrames:2
ConnectMode:0x00000010
TimeZone:20
NTPIP:
UseTftp:1
CfgInterval:60
TraceFlags:0x00000000
DialPlan:911|1>#t8.r9t2-|0>#t811.rat4-|^1t4>#.-
RingOnOffTime:2,4,25
DialTone:2,31538,814,30831,2032,0,0,0,0,0,0
DialTone2:2,30743,1384,29864,1252,0,0,0,0,0,0
BusyTone:2,30467,1104,28959,1404,1,4000,4000,0,0,0
ReorderTone:0,2,30467,1104,28959,1404,0,0,1,2000,2000,0,0,0,0,0,0
RingBackTone:2,30831,2032,30467,1104,1,16000,32000,0,0,0
CallWaitTone:1,30831,2412,0,0,1,2400,2400,0,0,4800
MediaPort:16384
SigTimer:0x00000064
VoiceMailNumber:
DisplayName:
ShortName:0
TimeFormat:h:ia
DateFormat:m/d/y
CallWaiting:1
AttendedTransfer:1
BlindTransfer:1
Conference:1
