Can the Vpn client map network drives?
Feb 8th, 2007
We are using Pix 515e and the Vpn client 4.6. I am running on my network Desktop Authority to maps drives and I need the drives mapped for my users after logon through Vpn. Can the client launch that bat file?
Thanks.
bwilmoth Wed, 02/14/2007 - 06:50
You will need to use a combination of WINS and lmhost files in order to browse your network and map network drives. The pc the vpn client is installed on will need to have a lmhost file pointing to the WINS server
Kamal Malhotra Wed, 02/14/2007 - 07:20
Once you are done with the WINS and lmhosts config and want the VPN client to launch the bat file when it connects, you can do the following :
1. Open the VPN client application.
2. Goto Options > Application Launcher.
3. Check the 'Enable' option and then browse the bat file.
4. Click OK and then connect.
Please see how it goes.
HTH,
Kamal
