Collisions detected in a Catalyst 4500
Feb 8th, 2007
I have some problems with a WS-X4515 and a Broadcom NetXtreme Gigabit 5703. If I do a sh interface it will be appear collisions in that interface.
Overall Rating: 4 (1 ratings)
contratoscisco@... Thu, 02/08/2007 - 08:47
Thank you for the advice but I don't use a shared medium. The server is connected to the switch directly.
The connection is a Gigabitethernet.
cprice2k7 Thu, 02/08/2007 - 08:51
In that case the collisions would be caused by a bad nic or cable. Have you tried replacing the cable or nic? You could also try moving the connection to a \different port on your switch to eliminate the port as the problem.
contratoscisco@... Thu, 02/08/2007 - 09:46
I have tried this but the problem persist. The problem only exists with the Broadcom NIC because I have others NICS and they don't have any problems
