Barge in key grayed out in CSD
IPCC server's NIC binding order is such that the NIC that is disabled is listed first and the active NIC is listed second, need to switch that, List the enabled NIC first and the disabled NIC second.
The primary NIC should be listed first, and the secondary VoIP Mon NIC should be listed second. If it's not, make that change and reboot the server.
