02-08-2007 09:01 AM - edited 02-21-2020 02:51 PM
Hi, I've had this 501 for several months now and really stuggled to get the client VPN side working.
I can get site to site working with no problems using the wizard but the Client VPN never works.
Latest i've set it up for pptp which I can get the client to connect with no problems but fails to get any traffic from the pix - I can however ping the remote PC from a PC behind the PIX.
I'm setting these up by the PDM buy i've attached a copy of the config anyway.
Best,
Chris
02-09-2007 08:36 AM
Hi, Has anyone got these 501's working in a vpn client form ?
The PDM wizard doesnt seem to work and Cisco wont help unless you buy a contract with them... Seems a little unfair as it appears as though the product doesnt work.
I've also posted this to several other forums and so far nothing.
02-09-2007 09:55 AM
Set it up through hyperterminal not the gui. Go here, I had the same issue.
02-09-2007 04:36 PM
Hi Chris,
I'm not sure why the PPTP clients are not able to access the inside resources. We'll need to capture the traffic to get that information but if you want to Cisco VPN client, then you can configure the following commands on the CLI, and it should work :
access-list split permit ip 192.168.1.0 255.255.255.0 any
no access-list inside_outbound_nat0_acl
access-list nonat permit ip 192.168.1.0 255.255.255.0 192.168.10.0 255.255.255.0
nat (inside) 0 access0list nonat
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map cisco 1 set transform-set myset
crypto map dyn-map 20 ipsec-isakmp dynamic cisco
crypto map dyn-map interface outside
isakmp nat-t
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
vpngroup VPNclient address-pool pool
vpngroup VPNclient idle-time 1800
vpngroup VPNclient split-tunnel split
vpngroup VPNclient password
Please make sure to configure your own password.
Hope this helps.
Kamal
02-12-2007 02:05 AM
Hi Kamal.
It didnt like the command
I can attach via Cisco VPN Client but the same occurs - I can ping the remote from the network - but not the other way round.
Config attached. - Best, Chris
: Written by enable_15 at 02:14:05.990 UTC Mon Feb 12 2007
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside_cryptomap_dyn_20 permit ip any 10.10.10.0 255.255.255.240
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 213.x.146.72 255.255.x.0
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 10.10.10.1-10.10.10.10
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.x.249.x.65 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication LOCAL
isakmp nat-traversal 20
isakmp policy 10 encryption 3des
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpn address-pool vpnpool
vpngroup vpn dns-server 192.168.1.1
vpngroup vpn idle-time 1800
vpngroup vpn password 634083
vpngroup VPNclient password ******
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd dns 89.238.129.211
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
username chris password 9DgK/T8KJkq.BhX6 encrypted privilege 15
terminal width 80
Cryptochecksum:xxx
: end
02-12-2007 11:36 AM
it was a typo it should be
nat (inside) 0 access-list nonat
02-12-2007 05:15 PM
Hi Chris,
It was a typo. Sorry :-P
Kamal
