Cisco 1600 User Access Authentication
Feb 8th, 2007
Hi, I bought a Cisco 1600 ROUTER off Ebay, its a used one; while booting it prompts me to put a USER ACCESS AUTHENTICATION PASSWORD. Please can someone advice on how to follow this?
Nasser
Collin Clark Thu, 02/08/2007 - 09:59
Sounds like someone forgot to clear their config before sending it to you. To reset the passwords you will need to perform password recovery on it. Hopefully you got a console cable with the router (should be flat and is typically blue or black). Here are directions on the password recovery.
http://cisco.com/en/US/products/hw/routers/ps214/products_password_recovery09186a0080093e11.shtml
HTH and please rate
nasatic72 Thu, 02/08/2007 - 10:34
Hi, i cant even access the router; it prompts me to enter user access verification password.
nasatic72 Thu, 02/08/2007 - 10:46
Thanks for ur respone, I have a console cable already, else it cant connect to the pc; its a sky blue colour. I have connected it as instructed,but it takes me to the same prompt
Collin Clark Thu, 02/08/2007 - 10:50
Please read the directions carefully. You need to power cycle the router and enter the Break sequence to gain access.
nasatic72 Thu, 02/08/2007 - 11:39
Bravo! its done, thanks a million for your help. I appreciate your time and energy. God bless
zzzz Nasa
