IPv6 on bridged virtual interface (bvi), 871W
Feb 8th, 2007
Can someone help me configure IPv6 on my Cisco 871W router.
I HAVE succesfully setup a IPv6/IPv4 tunnel to a tunnel broker. I am able to ping (ipv6) over the tunnel but am unable to ping locally connected IPv6 devices.
My guess is that this has something to do with having ipv6 enabled a non-ethernet interface. My router is using bridging to join the wireless and wired interfaces. I already had to explicitly enable router advertisements because BVI1 is not considered a LAN interface.
Sniffing on other locally connected devices tells me the router is not answering to neighbor solicitations.
Why can't I fullfill this easy task of establishing local ipv6 connectivity.
Erik Tamminga
My current config (the ipv6 relevant parts) is...
ipv6 unicast-routing
ipv6 cef
ipv6 dhcp pool IPv6-Vlan1
prefix-delegation 2001:xxx:xxx::/48 2001xxxxxx
domain-name ipv6.etamminga.nl
ipv6 inspect name IPv6-Firewall tcp
ipv6 inspect name IPv6-Firewall udp
ipv6 inspect name IPv6-Firewall icmp
ipv6 inspect name IPv6-Firewall ftp
ipv6 multicast-routing
bridge irb
interface Tunnel1
description IPv6 uplink to XXXX
no ip address
ipv6 address 2001:xxx:xxx:371::2/64
ipv6 enable
ipv6 traffic-filter IPv6-inet-in in
ipv6 inspect IPv6-Firewall out
tunnel source FastEthernet4
tunnel destination 192.87.xxx.xxx
tunnel mode ipv6ip
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
ip pim sparse-dense-mode
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1412
ipv6 address 2001:xxx:yyy::1/64
ipv6 enable
ipv6 nd prefix 2001:xxx:yyy::/64 86400 86400
ipv6 nd other-config-flag
ipv6 nd router-preference High
no ipv6 nd ra suppress
ipv6 nd ra interval 30
ipv6 dhcp server IPv6-Vlan1
ipv6 route 2001:xxx:yyy::/48 Null0
ipv6 route 2000::/3 2001:xxx:xxx:371::1
ipv6 access-list IPv6-inet-in
permit tcp any host 2001:xxx:xxx:371::2 eq 443
permit udp any any eq non500-isakmp
permit udp any any eq isakmp
permit esp any any
permit ahp any any
permit udp any any eq ntp
permit udp any eq domain any gt 1024
permit icmp any any echo-reply
permit icmp any any time-exceeded
permit icmp any any unreachable
permit icmp any any echo-request
permit icmp FE80::/10 any
deny ipv6 any any log
bridge 1 protocol ieee
bridge 1 route ip
etamminga Sat, 02/17/2007 - 03:59
Well, IPV6-inet-in is not attached to interface BVI1. So that's not the problem...
Any other thoughts?
Erik Tamminga
etamminga Sat, 02/17/2007 - 13:40
On several websites on the internet bug CSCej50923 is mentioned in combination with IPv6 and the bridging capabilities of the Cisco ISR routers.
CSCej50923 cannot be found in the Cisco bug toolkit.
Can someone from cisco give us a statusupdate on this bug?
Erik
