IPCC 4.0(4) default share desktop_cfg missing
mauricioaduna
Hello to everyone, I?ve installed CRS 4.0(4) with the manual in hand (Cisco CRS Installation Guide 4.0(4).pdf) At the end, I cant install the agents on clients because the default share DESKTOP_CFG is not available, I?ve tried to manually share it, but the clients keep sending the error that The parameter is incorrect and the next page, Options, is empty. Does anyone knows what is happening? Please I need help!
Thank you, best regards,
Mauricio Aduna
(please, forgive my poor english)
c.donnelly
OK - with 4.0(4) you do NOT need a DESKTOP_CFG share which makes life a lot easier for all concerned. I guess that you have the incorrect manual :-)
Chris
Hey thank you! yes I found that just today a few hours ago. And the major problem is Internet Explorer 7 !!! With IE7 you have a lot of troubles, I've uninstall it, and everything start to work just fine.
Thank you!
Best Regards,
Mauricio Aduna
