02-08-2007 08:33 PM - edited 07-03-2021 01:36 PM
Hi All,
I have a multi vendor wireless network where some of the AP's require the vlan name ( trapeze AP's ) to be returned from the radius server ( ACS ), whereas the Cisco AP's require the VLAN ID ( numerical value) to be returned. Any thoughts as to how we can get the two to interop? Is there any way to get the Cisco APs ( 1200's mostly) to recognize the vlan name?
any suggestions would be greatly appreciated,
thanks!
Chris
02-14-2007 01:01 PM
Refer to the Using VLANs with Cisco Aironet Wireless Equipment doc.
02-14-2007 02:24 PM
Hi Chris,
Yes it is possible. From gui kindly go to
Services> Vlan > Select Vlan from current Vlan and Tag them with Vlan name. And hit on apply.
This will allow you to use both Vlan number and Vlan name .
Thanks ,
kunal
