02-02-2007 11:55 AM - edited 03-05-2019 02:08 PM
when troubleshooting the switchport, when ping to else IP address from my laptop, it is ok, but ping the local IP address, unreachable.
02-02-2007 11:55 AM
which ip you are trying to ping ? and can you post the output of ipconfig /all and also which ip you are trying to ping ...
Also how you have got connected in your local network..
regds
02-09-2007 02:26 AM
Hi!
Check if you're using a PC that has a built in firewall. For windowsXP, either temporarily close the Firewall or go to firewall advance ICMP settings and check on allow ICMP echo requests. Also check for other firewall applications.
Hope this helps, Please rate if found helpful
Albert
03-05-2007 05:19 AM
R U talking about ur laptop IP.
