Can ACS 3.3.4 have Cisco Aire-QoS-Level Radius Attribute?
Feb 9th, 2007
Understand that ACS 4.1 has build-in support for Cisco Airespace VSA (Aire-QoS-Level) Radius Attribute. We are running ACS 3.3.4 and can someone advise if we can manually coded this Cisco-Airespace attribute our ACS?
pppyyyppp Fri, 02/09/2007 - 20:45
Is there an example on how to do this (we are trying to code the Cisco-Airespace radius attribute (Aire-QoS-Level) to ACS3.3.4
I have read the document but still have do not understand how to code the ini file. What should I put for following VSA readings:
[User Defined Vendor]
Name=Cisco-Airespace
IETF Code=026
VSA 1=
VSA 2=
[your vsa]
Type=INTEGER
Profile=OUT
amrkrish Fri, 02/09/2007 - 22:31
I hope this should work. Please take a back up of your entire ACS before adding this UDV.
Name=Cisco Airespace
IETF Code=14179
VSA 2=Aire-QoS-Level
[Aire-QoS-Level]
Type=integer
Profile=OUT
Enums=Aire-QoS-Level
[Aire-QoS-Level]
0=Bronze
1=Silver
2=GOld
3=Platinum
4=Uranium
amrkrish Sun, 02/11/2007 - 10:25
As it is a wireless device, you will need to use regedit to associate it with GenericEAP.dll.
pppyyyppp Mon, 02/12/2007 - 01:12
I have create the .ini file and have use the CSUtil.exe to import the UDV into ACS. I am able to see the Cisco-Airespace attribute. However, the authentication failed. I sniffed at the ACS 3.3 and see the Radius Access-Reject message.
You have mentioned "As it is a wireless device, you will need to use regedit to associate it with GenericEAP.dll.", can you please advise how to go about doing this in ACS 3.3?
Many thanks.
