CSS ftp script
Feb 9th, 2007
I use a CSS to load-balance ftp server. To validate the availability of my ftp servers, I would like to write a script that logs on each ftp server and then tries to get a copy of a small file on the server (the file are not stored locally on the ftp server, so I need this to validate that the server is able to retrieve the file from my storage).
Is it technically possible or not using scripts ? (the ftp script provided by Cisco only logs on the server)
If yes, has anyone already done this ? How can I do this ?
Gaetan
Gilles Dufour Fri, 02/09/2007 - 16:10
Gaetan,
you could take the existing scripts and add more function to RETR a specific file.
However, downloading the file itself would be difficult and useless.
I would suggest to just send the RETR command and check the server response.
Gilles.
