IPsec
Feb 9th, 2007
I have applied IPsec in Two routers which is connected through public network(cisco 1841 with IOS advanced security) .Now how can I make sure that it is working fine?please Help me.
Collin Clark Fri, 02/09/2007 - 06:56
In the router enter the command 'show crypto isa sa'. If all is working you should see a tunnel.
dst src state conn-id slot status
6.7.1.5 7.23.2.10 QM_IDLE 1 0 ACTIVE
HTH and please rate
