Log Guest access
Feb 9th, 2007
Is it possible to log guest access when using guest webaccess and accounts created by the lobby admin?
One of our customers wants to use the feature if it is possible to keep track of when users were granted access via guest access. Can this be done via accounting?
Overall Rating: 4 (1 ratings)
claeysg Fri, 02/09/2007 - 05:34
Today, there are two options available depending if you use an anchor controller or not.
Option 1 (no anchor required): you can send accounting records to a Radius server. You will get the following info:
"Date","Time","RAS-Client","Record-Type","Full-Name","Auth-Type","User-N
ame","NAS-IP-Address","NAS-Port"....."Called-Station-ID","Calling-Statio
n-ID","NAS-Identifier"... "Acct-Session-Id"...
"09/03/2006","23:30:01","192.168.0.15","Start","Unknown","Unknown","Gues
t","192.168.0.15","29",,,,,,,,,,,,,,,,,,,,"192.168.0.15","192.168.201.74
","4400-C5",,"1",,,,"44fb9db3/00:40:96:aa:5c:83/25","1",,,,,,,,,"13","6"
Option 2 (requires an anchor controller). You can log the guest user access.
YOu have to enter the following commands on the anchor controller:
> config msglog level verbose
> show msglog
Fri Nov 3 15:08:06 2006 [SECURITY] aaa.c 661: Authentication succeeded for admin user 'admin'
Fri Nov 3 15:07:01 2006 [VERBOSE] pem_api.c 5839: Guest user logged out with user account (guest123) MAC Addr 00:40:96:ad:12:39 IP Address 172.20.225.149
Fri Nov 3 15:06:11 2006 [VERBOSE] pem_api.c 5761: Guest user logged in with user account (guest123) MAC Address 00:40:96:ad:12:39 IP Address 172.20.225.149
Fri Nov 3 15:06:11 2006 [SECURITY] aaa.c 666: Authentication succeeded for net work user 'guest123'
Fri Nov 3 15:05:30 2006 [VERBOSE] apf_foreignap.c 1075: Guest user with MAC Address 00:40:96:ad:12:39 assigned IP Address 172.20.225.149
Hope it helps,
Rgds,
Gaetan
Trending Topics - Security & Network
