Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929222members
1243398discussions
Community Activity
Allow ISE captive portal DNS entry on outside DNS.
Hello,We are having ISE for EAP/TACACS authentication and, hosted internally in our datacenter.Now we have configured BYOD captive portal that tied to AZURE SAML authentication, the current captive portal redirect URL from ISE has prepended the node ...
kshah2589 by Level 1
  • 1574 Views
  • 27 replies
AP issue
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine: AdvancedCountry CodeUS  Multiple CountriesUSStatistics Timer180CAPWAP MTU1485AP Link LatencyEnabledAP PMK Propaga...
Resolved! Best practice lan configuration
HiI have 4 Cisco 2960 switches and 3 unmanaged switches. All are connected via fiber cable to a core switch 4503-3 and it is connected to a VPN router and internet router. (still don't have access to the routers yet)I know I have to replace the unman...
Redundancy Over VSAT Link
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
inhamit by Level 1
  • 210 Views
  • 8 replies
Joining ISE to a Reversed DNS Zone
I have joined ISE on the same reversed zone as 50.168.192.in-addr.arpa (ise1.srvcore.local), but ISE have an address of 192.168.99.35.ISE could resolve and ping DNS domaine names on Windows Server and could PING its name "ise1.srvcore.local" and can ...
Jason2005 by Level 1
  • 100 Views
  • 4 replies
NTP and Syslog packets with specific IP Address
Hi All,I have a couple of C9300 L3 switches that are connecting to an ASA firewall. The NTP and the syslog server for the switches are located behind a firewall.When one of the switches request/send packets the gateway IP is the source address on the...
Ranjita by Level 1
  • 45 Views
  • 2 replies
WSA
hello all, is it possible to access physical cisco WSA GUI without  license ???
yoseph by Level 1
  • 41 Views
  • 1 replies
The operation took longer than expected.
I have just synchronized both Active Directory and Cisco ISE, ISE is using my server (AD) as an NTP server, everything is fine, but now I'm facing an issue "Status Summary: The operation took longer than expected. This may be caused by slow network c...
  • 154 Views
  • 8 replies
Call Handler Not Reachable From Outside Call
Hi Experts,I am sitting with an unique issue where my Auto Attendant works perfectly from inside the office, however it is not reachable from external calls.Connection ISP > SIP > CUBE > SIP > CUCMWhat I am seeing is as soon as I direct the call to C...
