subnetting
Feb 9th, 2007
Hi all, if I have subnet say 172.16.4.7/27
what would the first network be ? would it start 172.16.4.0 to 172.16.4.31
or would I start from 172.16.0.0 ?
uvaraj Fri, 02/09/2007 - 04:40
Yes, for 172.16.4.0/27 network host address range would be 172.16.4.1 - 172.16.4.30 , 0 is network address and 31 is broadcast.
For 172.16.0.0/27 network host address range would be 172.16.0.1 - 172.16.0.31 , 0 is network address and 31 is broadcast.
carl_townshend Fri, 02/09/2007 - 05:17
Hi thanks for that, So does that mean for example 172.16.0.0/27 would include all the eay from 172.16.0.0 to 172.16.255.224 ? and if it was 172.16.4.0/27 would this go from 172.16.4.0 to 172.16.255.224 ?
thanks
CSCO10892433 Fri, 02/09/2007 - 16:26
Hi, carl
Subnetting of 172.16.0.0/16 into many equally subnetted /27 blocks would include all the way from 172.16.0.0/27 to 172.16.255.224/27,
and subnetting of 172.16.4.0/24 into many equally subnetted /27 blocks would go from 172.16.4.0/27 to 172.16.4.224/27
SSLIN
CSCO10892433 Fri, 02/09/2007 - 04:49
Hi, carl
It depends on what the "parent subnet" is.
If you subnet a 172.16.0.0/16 network into many /27 blocks, the first subnet will be 172.16.0.0/27.
If you subnet a 172.16.0.0/23 network into many /27 blocks, the first subnet will be 172.16.3.0/27.
If you subnet a 172.16.4.0/24 subnet into many /27 blocks, the first subnet will be 172.16.4.0/27
If you subnet a 172.16.4.0/26 subnet into two /27 blocks, the first subnet will be 172.16.4.0/27
SSLIN
carl_townshend Sun, 02/11/2007 - 15:54
Can anyone give me an example of what subnets we would have with say 10.1.1.5/27, would my first network be 10.0.0.0, second 10.0.0.32 etc ? right the way to 10.255.255.224 ?
