Voice vlan data vlan on C3560 and dhcp server
Feb 9th, 2007
I want to configure voice vlan and data vlan in c3560 ... and dhcp server of each vlan on windows server...
do we need a switch with layer 3 functionality to do routing between different vlans ?? if so does cat 3560 has layer 3
can someone please help me with this
Overall Rating: 5 (1 ratings)
Dennis Fogler Fri, 02/09/2007 - 06:08
The standard image on a Catalyst 3560 is layer 3. Just turn ip routing on in the switch with the "ip routing command". Routing between the VLAN on the switch will then happen.
Some of the newer standard images on the Catalyst 3560 will even allow you to run "EIGRP Stub".
