Outbound dialer with a prompt only
Feb 9th, 2007
I'm looking for suggestions on how to write an outbound dialer script that queries a database/XML file for a phone number. The script then dials the phone number and plays greeting/prompt and then ends the call.
Is this doable or do a need the Cisco Outbound dialer option?
Joe
adignan Sat, 02/10/2007 - 18:21
I would write a http triggered script so you can always have it running.
Then, in your script you would just query sql, use the place call step > play the .wav file to the customer > use the terminate step to end the call.
please rate helpful posts.
