RME restorebackup: configuration files import
Feb 9th, 2007
Hi to all..
I'm going to do restorebackup from LMS 2.2 to LMS 2.6 on solaris 8
my migtration.log file, trace the following:
09/Feb/2007 16:10:41:125 3244068 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain 613 - File path is /opt/CSCOpx/tempBackupData/rme/cw2000/files/archive/config/769/20050701234136running.cfg
Warning - No current logger set
09/Feb/2007 16:10:42:897 3245840 [main] INFO com.cisco.nm.rmeng.migration.MigrMain 599 - Archive created for 770
seems that the config file was created.
But the path /opt/CSCOpx/tempBackupData/rme/cw2000/files/archive/config/769/20050701234136running.cfg
doesn't exist!
I've
/opt/CSCOpx/tempBackupData/rme/opt/CSCOpx/files/archive/config/769/20050701234136running.cfg
I have .../opt/CSCOpx/.. instead of .../cw2000/... directory
I have to stopping the process and make a link to the existant directory?
Maybe the restore will be fail or configuration files will not import?
Leonardo
Overall Rating: 1 (1 ratings)
Joe Clarke Fri, 02/09/2007 - 14:26
When the archives are created for LMS 2.6, they are stored in /var/adm/CSCOpx/files/rme/dcma/devfiles. I see no indication that there are any failures from this log snippet.
