02-09-2007 07:29 AM - edited 03-11-2019 02:31 AM
How is possible to filter some routers from another routers , in the inside interface , if I have set OSPF in that interface .
Distribute-list is not able to use ....
And , the reverse route rejection is not functioning . I enable DPD and Reverse-route-injection in this equipment , with 7.2(2) , but is not functioning . I made that in a site to site VPN .
Best Regards
02-15-2007 06:37 AM
You cannot use distribute lists as all the routers are required to have identical database in an area. Please be more clear in putting accross your problems as it's very critical for giving an exact reply.
02-20-2007 01:39 AM
Your problem is not clear enough. It seems you have injected route for the network & hosts which are protected by remote end tunnel.
But the route filtering part is not clear to me. What exactly you want to filter on the OSPF.
mrinmoy
