Global Way to enable Portfast?
Feb 9th, 2007
I need to enable portfast on about 100 switches in different buildings. What is the fastest way. Even if I could do a whole switch at once.
thanks
eofelt Fri, 02/09/2007 - 08:16
IOS:
Switch(config)# spanning-tree portfast bpduguard default
(All ports that have PortFast enabled also have BPDU guard automatically enabled. )
CatOS:
set spantree portfast bpdu-guard enable
gary.hostetler Fri, 02/09/2007 - 08:18
thanks,
Is there any way from Network Assistant? If not I'll use the command line.
Gary
royalblues Fri, 02/09/2007 - 08:43
All ports can be configured for portfast on a single switch with the command given in the above post.
To have it on all the switches, use something like the netconfigs on the Cisco works
Narayan
eofelt Fri, 02/09/2007 - 08:44
Sorry Gary,
I have not used Network Assistant.
I pretty sure Cisco Works can do batch type work and a lot more. See if you can Google "Kiwi Cat tools" -a free download for management.
IMO 100 isn't too much, a pain yes but not too many providing you don't have a tight change window etc.
hth, please rate
Erik
Michael Sales Sat, 02/10/2007 - 06:06
on all the switches for exception of the 3500XL series, you can use the "int range" command. for instance:
config t
int range fa0/1 - 24(48)
span portfast
This will enable portfast on all ports 1 through 24 or 48. it's the fastest way.
you can use a script from CiscoWorks or 3rd Party app to make the changes Automated.
I hope this helps
gary.hostetler Sat, 02/10/2007 - 07:04
I am ordering the latest CiscoWorks Small Business 1.5.1 version. I will wait until then. I need to get my Ciscos in shape as I need to push out the latest IOS images etc. I have 1.5 but it won't run on a 2003 server and Cisco isn't progressive enough that you can download and use an updater.
Gary
