Unity 4.0.5 text to speech not working.
Feb 9th, 2007
Windows 2000 server with license for tts. System says unable to read message at this time, try again later ? doe's anyone have a answer to this.
sopayne Fri, 02/09/2007 - 09:14
Have you confirmed that the TTS service is started?
Good luck.
maratimer_2 Mon, 02/12/2007 - 05:30
Not sure of your exact symptoms but you may want to look at this:
CSCsd26042 - Realspeak engine buffer overflow results in email TTS failure.
ES61 for Unity 4.0.5 fixes this.
clindsey22 Mon, 02/12/2007 - 06:04
I rebooted the server and all is fine. I will need to apply patch for this known bug. Thank you for all your help.
