Unknown number from IP Phone
Feb 9th, 2007
Hi all,
I have a call manager 4.0 running and a voice gateway configured with DID.
When i call from my GSM phone to the IP phone the number doesn,t appear on the IP Phone.
How can i make it appear
Note: I m using FXO port not E1
Eric
Overall Rating: 1 (1 ratings)
jbarcena Fri, 02/09/2007 - 08:45
Is your GW configured as MGCP or H.323?
caller ID is not supported on FXO with MGCP.
Paolo Bevilacqua Fri, 02/09/2007 - 09:17
Beside the the MGCP issue it appears that caller-in on DID lines is not supported on 4FXS/DID card.
In which country is this. ? What is the DID signaling scheme ?
I couldn't even get confirmed from discussion in another thread, that caller id on DID is supported by some telco in the US.
jbarcena Fri, 02/09/2007 - 10:26
I recommend you to take a debug on the GW and a CCM detailed trace to see exactly what the GW is receving/sending and also what the CCM is sending/translating.
