VG 224 Transfer
Answered Question
Feb 9th, 2007
please note that my client have VG224 configured as MGCP gateway with CCM 4.13
currently analogue phones can transfer but in blind mode, could it be possible to do a consultative transfer.
in case yes, how to do it, i could not find any doc on the net.
if i need to change the mode from MGCP to SCCP, it would be no problem.
thanks
Correct Answer by rob.huffman about 9 years 7 months ago
Hi Wissam,
According to this VG224 doc, Consult Transfer is supported with SCCP. Have a look;
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_data_sheet09186a00801d87f6.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
thilanjayathilake Tue, 05/15/2007 - 23:10
I have configured vg224 with the call manager with SCCP .but stil the call transfering is not working. when i press the flash (Hook flash ) it will not switch to transfering mode
martin.plank Mon, 06/23/2008 - 12:56
I've configured 7 VG224 for SCCP, Max. Calls on CUCM5.1.2 ist set to 2, but Call transfer doesn't work. On my VG224 i have SW 12.4
wcarvalh Wed, 10/22/2008 - 11:10
Hi guys,
I was having this problem and it was solved setting "Maximum Number of Calls"! Thank's for the tip!
