7906 not working in SRST with 12.3(11)T11
Feb 9th, 2007
hi friends, i have this problem, when 7906 goes in SRST(Call-manager-fallback) they are unable to register with Gateway 2811 with that ios version, when they are registered with CCM all goes right.What is the problem? someone can help me?
thanks a lot for all
Paolo Bevilacqua Fri, 02/09/2007 - 09:21
Are both CM and SRST addressess appearing in the settings menu of 7906 ?
I would also upgrade anyway to 12.4(9 or 11)T to sort out any bug in older version.
At the same time check the load revision on the phones.
matteo.margheritini Sun, 02/11/2007 - 23:50
Yes, now I'll try with another ios. It can be a possible bug in older version. Thanks for all. I try.
