Any translation rule gurus
Feb 9th, 2007
The documentation is baffling to me and is probably right before my eyes, but here is what I want to do.
In normal mode with MGCP gateways, we are taking 10 digits inbound on our PRI. In CCM, I am taking the last 4 digits and prepending a 4. So 1234 turns into 41234 as a DN
I want to be able to do the same thing in SRST mode. So I need a translation rule that says take the last 4 and add a 4.
So for example even if wrong
/..../ /4..../ Whatever the proper wilcards are.
Thanks to all
Overall Rating: 4 (2 ratings)
Brandon Buffin Fri, 02/09/2007 - 11:18
Assuming that inbound calls are to number in the block 1112223XXX, the following translation rule will translate anything beginning with 1112223 to a number beginning with 43. The remaining digits will be carried through.
voice translation-rule 1
rule 1 /^1112223/ /43/
voice translation-profile 1
translate called 1
dial-peer voice 1 pots
incoming called-n .
direct-inward-dial
translation-profile incoming 1
Hope this helps. If so, please rate the post.
Brandon
PETER NEGUS Mon, 02/12/2007 - 09:44
a slightly nicer way is
voice translation-rule 4
rule 1 /.*\(....\)$/ /4\1/
voice translation-profile STRIP-DNIS
translate called 1
dial-peer voice 9 pots
translation-profile in STRIP-DNIS
incoming called-number .
Or try [assuming your DID is 666555xxxx]
call-manager-fallback
dialplan-pattern 666555.... extension-length 5
extension-pattern 4....
Which does it all in one command, but litters the system with hidden dial-peers.
