Cisco IP phone
Feb 9th, 2007
I have a 7960 cisco ip phone, how do i forward a call that comes to my extension to my cell phone which is a (805)***-****. Thanks
jbarcena Fri, 02/09/2007 - 13:25
You can use the CFwdALL softkey on your IP Phone then set the number as you are required to dial from your phone, for example 9805XXXXXXX, or you can use the CCMUser or CCMAdmin page to set your forward options. As long as the CSS of the phone or the forward settings can reach the Route Pattern that dials the cell phone you should be ok.
Paolo Bevilacqua Fri, 02/09/2007 - 13:27
If have a soft button "call forward" on the phone, from there. If you don't such softbutton, or when you try doesn't work, ask your phone admin ?
scripttron75 Fri, 02/09/2007 - 13:31
I know that but when i hit the cwdfwdall button i can not put that number in only a 3 digit ext
jbarcena Fri, 02/09/2007 - 13:34
What is the CCM version including Service Release(SR) or Engineering Special (ES)?
Are you able to set the CFA on the CCMAdmin page? Does it work from there?
Are you able to dial the cell phone directly from your IP Phone?
Paolo Bevilacqua Fri, 02/09/2007 - 13:34
That is because the callmanage is configured to not allow extrnal extension and that's why I said you should ask your sysadm about that.
jbarcena Fri, 02/09/2007 - 13:44
Device --> Phone --> select the line that you want to forward.
scripttron75 Fri, 02/09/2007 - 14:00
can any of you guys recommend a good book or tutorial on how to use call manager and what the functions and features are of it??
jbarcena Fri, 02/09/2007 - 14:06
Cisco CallManager Fundamentals, 2nd Edition
By John Alexander, Chris Pearce, Anne Smith, Delon Whetten.
Published by Cisco Press.
Configuring CallManager and Unity: A Step-by-Step Guide
By David Bateman.
Troubleshooting Cisco IP Telephony
By Paul Giralt, Addis Hallmark, Anne Smith.
Also take a look to this link, you can enter to each version and get documentation on almost everything that can be done on each CCM version.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/index.htm
