IAD 2431 with ATM
Feb 9th, 2007
OK,
Trying to get a 2431 IAD to work with an ATM T-1. Interface comes up, PVCs come up, but no IP connectivity. Traffic counters on the interface and PVCs increment, but no IP (ping) connectivity. Can't even ping myself.
Config below
version 12.4
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname Router
boot-start-marker
boot-end-marker
card type t1 1
logging buffered 51384 debugging
enable password cstc
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
network-clock-participate T1 1/0
network-clock-participate T1 1/1
network-clock-select 1 T1 1/0
ip arp gratuitous local
voice-card 0
controller T1 1/0
mode atm
framing esf
linecode b8zs
controller T1 1/1
framing esf
linecode b8zs
interface FastEthernet0/0
ip address 24.97.148.116 255.255.255.240
duplex full
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM1/0
ip address 10.33.1.1 255.255.255.0
no atm ilmi-keepalive
atm uni-version 3.1
arp arpa
arp timeout 900
pvc VoicePVC 5/185
vbr-rt 106 64 11
encapsulation aal2
pvc DataPVC 5/189
vbr-nrt 96 96 1
encapsulation aal5snap
protocol ip inarp
pppoe max-sessions 5
pppoe-client dial-pool-number 1
ip default-gateway 24.97.148.xxx
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 24.97.148.xxx
access-list 101 permit ip any any log
control-plane
line con 0
line aux 0
line vty 0 4
access-class 3 in
password cisco
login
ntp server 64.246.130.xxx
sho int atm 1/0
ATM1/0 is up, line protocol is up
Hardware is NetGX ATM TC
Internet address is 10.33.1.1/24
MTU 1500 bytes, sub MTU 1500, BW 1536 Kbit, DLY 20000 usec,
Encapsulation ATM, loopback not set
ARP type: ARPA, ARP Timeout 00:15:00
Encapsulation(s):, PVC mode
511 maximum active VCs, 2 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output never, output hang never
Queueing strategy: Per VC Queueing
721 packets input, 40376 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
919 packets output, 54482 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
sho atm pvc
Router#sho atm pvc
VCD / Peak Avg/Min Burst
Interface Name VPI VCI Type Encaps SC Kbps Kbps Cells Sts
1/0 VoicePVC 5 185 PVC AAL2 VBR 106 64 11 UP
( 64)
1/0 DataPVC 5 189 PVC SNAP VBR 96 96 1 UP
( 96)
sho ip route
Gateway of last resort is 24.97.148.113 to network 0.0.0.0
24.0.0.0/28 is subnetted, 1 subnets
C 24.97.148.112 is directly connected, FastEthernet0/0
10.0.0.0/24 is subnetted, 1 subnets
C 10.33.1.0 is directly connected, ATM1/0
S* 0.0.0.0/0 [1/0] via 24.97.148.113
Ping to 10.33.1.254 results in an "Incomplete" entry in the arp table.
wdrootz Thu, 02/15/2007 - 07:39
1. Saving the configuration and reload the router.
2. Do a "shut" and "no shut" to the interface after config.
