Unity bug CSCef62311 - is fix in 4.0(5), 4.2?
Feb 9th, 2007
Trying to confirm if bug id CSCef62311 (ES 94) is fixed in higher versions of unity besides 4.0(4) or not. Have client who had issue where this was needed and they are looking to upgrade from 4.0(4) and are concerned about the fix that ES 94 added being in future options since they have the timer set to 90 seconds instead of the 20 still.
Overall Rating: 5 (1 ratings)
eschulz Fri, 02/09/2007 - 16:12
Yes, the fix was included in 4.0(5) and carried forward to future version of Unity.
Erick Bergquist Fri, 02/09/2007 - 16:16
Thank you for the info.
Would the Unity DST fixes effect current applied ES patches or all those be OK?
