Administrattive Distance
Feb 9th, 2007
What is the Administrattive Distance Of Default Route
Anand S Fri, 02/09/2007 - 23:20
HI Baby,
for RIP ver.1 & 2 it is 120,IGRP - 100, EIGRP 90 & OSPF 110.
smothuku Sat, 02/10/2007 - 00:46
Hi ,
Suppose the next hop to default route is the exit interface then administrative distance is 0.
Ex:
RTR A (S0) ----------------------(S1)RTR B
192.168.1.0/32
ip route 0.0.0.0 0.0.0.0 192.168.1.1(RTR A S0 ip address)
If the next hop to default route is the other end router ip then administarive distance is 1.
Ex:
192.168.1.0/32
ip route 0.0.0.0 0.0.0.0 192.168.1.2 (RTR B S1 ip address)
Hope it help you.
http://www.cisco.com/en/US/partner/tech/tk365/technologies_tech_note09186a0080094195.shtml
satish
jain.nitin Sun, 02/11/2007 - 08:32
Hi, It depends on how you defined default route on device. If u define gateway as IP of next hope device in default route then AD will be one & if u define interface like serial 0/1 or fa0/1 or Dialer 0 then AD wud be 0 becaz these r directly connected interfaces. basically AD is define the preferences of route.
