replacing router question
Answered Question
Feb 10th, 2007
I am planning to replace my existing 2611 with 2811 (the same # of int) and I am finding a way to easily transfer the configuration to the new one. Will tftping works and easiest?
Any suggestions would be greatly appreciated.
Correct Answer by Paolo Bevilacqua about 9 years 7 months ago
After editing the interface naming in a text file, use any protocol to copy it as startup config file to the 2811.
Overall Rating: 4 (1 ratings)
Correct Answer
Paolo Bevilacqua Sat, 02/10/2007 - 07:44
gsriraman Tue, 02/13/2007 - 04:41
Dear George,
Transfering the entire config and IOS is not advisable and cannot be done.
The reason is, 2811 is an ISR Router and has many other features for Voice & Video.
Secondly, the Interface numbers may not be the same
Hence I suggest the following:
Take a Text Copy and do it manually.
This is my experience that I am sharing
georgecisco01 Tue, 02/13/2007 - 05:45
Thank you very much for all your advise and suggestions. It's truly appreciated.
