CTI application failed to open provider
Feb 10th, 2007
Call Manager 4.1.3sr4d.
I am receiving the following errors in the app log every few seconds:
Error: kCtiProviderOpenFailure - CTI application failed to open provider
CTIconnectionId: 28
Login User Id: CCMSysUser
Reason code.: -1932787616
IPAddress:
App ID: Cisco CTIManager
Cluster ID: CISCOCM-Cluster
Node ID: CISCOCM
Explanation: Application is unable to open provider.
Recommended Action: Check the reason code and correct the problem. Restart CTIManager if problem persists..
CTIconnectionId: 29
Login User Id: IPMASysUser
IPAddress: 10.90.124.12
Node ID: CISCOCM
I am trying to configure IPMA and use the IPMA console. The console will not connect to the server either.
I refreshed all passwords with:
adminutility.exe
CCMPWDChanger
I am not integrated with AD.
I reset AC user account.
Anyone have any ideas on this one?
TODD BERGMAN Sun, 02/11/2007 - 13:03
OK I reset the IPMASysUser and CCMSysUser accounts. I used 12345.
Interestingly the errors have stopped is there some password restrictions on the complexity of these users?
gogasca Sun, 02/11/2007 - 22:49
Error code -1932787616 in hex is FFFFFFFF8CCC0060. This hex decodes to
CTIERR_DIRECTORY_LOGIN_FAILED. Which means that the CTI is having problem with passwords.
Some service like EM,IPMA,Webdialer were attempting to login using wrong passwords after you reset them all is good now.
This can be confirmed in SDL CTI trace.
TODD BERGMAN Mon, 02/12/2007 - 05:51
Thanks for your responses. I have reset all passwords including the AC user. The error remained. It wasn't until I reset the IPMASysUser and CCMSysUser with a basic password 12345 that the error subsided.
I originally reset the password with a Complex password and that didn't work. That it was what was perplexing.
Problem is solved thanks alot for your responses this Forum is awesome.
-Todd
mchandak Mon, 02/12/2007 - 06:25
Looks like the IPMASysUser password is out of sync. Can you reset the password for this account using CCMPwdChanger and restart CTIManager ??
