pix 520 licensing question
Feb 11th, 2007
I just bought a pix 520 from ebay my sh ver is
Licensed Options:
Failover: Enabled
IPSec: Enabled
Ports allowed: 6
I can't figure out what type of license it has
I know the pix what used in a failover enviroment.
vitripat Sun, 02/11/2007 - 09:54
This doesnt look like complete output from "show version" command. Do you see any line at the end sayin "This PIX has a XXXXX license." ? If not, you might be running on a old code. Though with this option "Failover: Enabled", it could either be UR/FO.
AbrahamBenguigui Sun, 02/11/2007 - 10:08
this is the complete output of sh ver:
PIX Version 4.4(1)
Compiled on Tue 18-May-99 16:34 by pixbuild
Finesse Bios V3.3
pixfirewall up 11 secs
Hardware: SE440BX2, 32 MB RAM, CPU Pentium II 349 MHz
Flash atmel @ base 0x300
0: ethernet0: address is 0090.272e.729c, irq 11
1: ethernet1: address is 0090.272d.8fc0, irq 10
Licensed Options:
Failover: Enabled
IPSec: Enabled
Ports allowed: 6
Serial Number: 18015518
vitripat Mon, 02/12/2007 - 11:12
As I thought, your PIX is currently running a version which is no longer supported by Cisco.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/prod_eol_notice0900aecd8056d289.html
Looking at the output, its difficult to comment if its a UR or FO-Only license. The bad news is that you cant upgrade this firewall to new versions also, till you dont upgrade your flash as well.
The current flash you have "Flash atmel" is only 2 MB in size, and 6.x code requires minimum 8 MB flash.
AbrahamBenguigui Mon, 02/12/2007 - 11:23
If i upgrade the flash can i do anything with it if its a failover license only?
How can I upgrade my license?
vitripat Mon, 02/12/2007 - 11:32
Absolutely. You can order PIX-FLASH-16MB=, which is the ideal replacement for your current flash. Therafter, you can also get the license installed on this device as required.
