Antivirus and Antispyware updates for CCA
Feb 11th, 2007
Can somebody give some information on how often does cisco.com, publishes the antivirus and antispyware updates for the clean access managers to downloads.
If a antivirus vendor publishes some updates ,within how many hours will it be available on cisco.com website.
thanks
sathappan.s
Overall Rating: 3 (1 ratings)
pmccubbin Sun, 02/11/2007 - 09:40
I've been told by Cisco they have updates from their partners in 60 minutes or less.
What's more, according to the latest version's documentation:
"Cisco conducts automatic, periodic downloads to the Cisco NAC Appliance so that administrators do not have to manually configure dynamic data, such as virus signatures."
Hope this helps.
nitinmathur Thu, 05/10/2007 - 21:35
I am not able to auto update the Clean Access and get following message. Can anyone suggest what can be the problem. The IP of CAM is nated on PIX forewall with any-any access list but still update is not complete. I would like to inform that it is a new install.
Thanks in advance
Cisco auto-update is scheduled to start 17:03:00 and repeat every 1 hours
You have the latest version (Ver. 4.1.1.0) of Windows Cisco Clean Access Agent installer
Rules could not be downloaded from the Cisco server
Supported AV/AS product list could not be downloaded from the Cisco server
Default host policies could not be installed
OS detection fingerprint could not be installed
Latest version (Ver. 2.0.1.2) of L3 Java Applet web client already installed
Latest version (Ver. 2.0.1.2) of L3 ActiveX web client already installed
OOB switch OIDs could not be installed
