CCM DST 2007 Update Only Needs Installed on Publisher?
Answered Question
Feb 11th, 2007
In reading the release notes for the DST 2007 Update (http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/crypto/3DES/voice/callmgr/4.1/ciscocm.4-1-3-2007-DST-Update.1-0-1-readme.htm&app=Tablebuild&status=showC2A) it says "Step 4: The Publisher will be rebooted at the completion of install. After the Publisher is back up, each server in the cluster must be rebooted in a sequential fashion, starting with the TFTP server and backup CCM Servers.". Just to be clear, you do NOT need to install the update on any Subscriber, TFTP server...etc, just reboot them after it has been installed on the Publisher? Thanks!
Correct Answer by Erick Bergquist about 9 years 7 months ago
You need to do the OS update on all the servers, and the 4.1(3) SR on all the servers, and upgrade the phoneload/firmware to a fixed version for some 7900 series phones (java based ones - ie: 7941/61/70/71, etc). See the DST field notice for the Unified IP Phones for details.
Then when you have all above updated, etc do the CCM DST patch on publisher. The readme for the CCM DST patch does explain this in good depth as to what order things need to be done in.
Main DST page:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00807ca437.shtml
IP Phone Field Notice for DST:
http://www.cisco.com/en/US/products/hw/phones/ps379/products_field_notice09186a00807d3d9e.shtml
Please rate helpful posts.
Overall Rating: 5 (2 ratings)
Erick Bergquist Sun, 02/11/2007 - 16:08
That's right. I asked TAC about this also. The update does a database update only, so SQL replication will pass the changes to the subscriber servers.
I also asked that they update the document to make this more clear also, since I had 3-4 clients ask this question.
MikeTomasko Sun, 02/11/2007 - 17:16
Thanks for the quick response!
What about the Windows 2000 portion of the patch then? I'm installing win-OS-Upgrade-K9.2000-4-4a, win-OS-Upgrade-K9.2000-4-4a-sr3a, then upgrading CCM to 4.1(3)SR4d and installing 4-1-3-2007-DST-Update.1-0-1.exe on the Publisher. Is that everything I need to do to update my Publisher and Subscribers for DST 2007? I'm currrently running OS Image 2000.2.7 and OS Service Release 2000.2.7sr3. Thanks!
Correct Answer
Erick Bergquist Sun, 02/11/2007 - 18:37
Main DST page:
MikeTomasko Sun, 02/11/2007 - 18:40
Thanks a million for the quick, detailed replies! I'm in the middle of the upgrade as we speak/type!
MikeTomasko Mon, 02/12/2007 - 10:29
Just a quick overview and update for anyone that maybe looking into updating their CCM. It took me about 1 1/2 hours per server to install all the updates. That includes the reboots. It was 7 or 8 reboots per server. Here's an overview of what I went from and what I went to:
Before
OS release 2000.2.7sr3
CCM Version 4.1(3)sr1
After
OS release 2000.4.4a.sr3a
CCM Version 4.1(3)sr4d
Additional Updates
7940 & 7960 SCCP 8.0.5
7970 & 7971?s SCCP 8.0.4sr2
4.1(3) 2007 DST Update 1.0.1
After the updates I used Microsoft's TZEDIT just to verify the Time Zone was edited. Good luck to anyone looking to do this!
I was fortunate and things went extremely smooth. Only came across 1 issue. We have 3 phones that the people had set to Call Forward All and after the updates they couldn't take off the CFWD All. I checked in CCM and there was no CFWD All number listed, but it was still forwarding. I had to put a number in the CFWD All box, update it, then remove the number and the phones began to then ring again and take calls. I submitted this "bug" to TAC.
rob.huffman Mon, 02/12/2007 - 11:11
Hi Mike,
Thanks for posting back with your updates.5 points from this end:)
Take care,
Rob
Hi Mike,
For some reason, I can't get the 7960 to work. Is there anything I'm missing? Does it take a while for the 7940/60's to sync up with the server?
I set it up in the lab and roll the time to March 11, 2007 1:58AM on the one callmanager server (no subscriber). When it hits 2AM, the callmanager server and the 7941/61/70/71 phones all correctly jump to 3AM. However, the 7960 is stuck at 2AM unless I restart it.
I did the following in this order:
updated the OS to OS4.3a(sr8)
updated callmanager 4.1(3) service release to to version 4.1(3)sr4d
updated 7941/61/70/71 phone loads to sccp 8.0.4sr2.
updated 7940/60 phone load was update to sccp8.0.5.
MikeTomasko Wed, 02/14/2007 - 12:03
Did you also install the 4.1(3) 2007 DST Update 1.0.1 patch?
I'm testing the roll over in my lab now.
rob.huffman Wed, 02/14/2007 - 12:17
Hi Van,
We saw the same thing in our lab tests. The older phone models 7940/7960 etc. take a little while to aquire the new time. If you leave them alone they will eventually pick up the correct time (DST Test). Like you have discovered, you can always boot the phones to speed up the process.
Hope this helps!
Rob
MikeTomasko Wed, 02/14/2007 - 12:18
I just tested this on a 7940 and a 7960. Even without the DST issue, I waited 5 minutes or more and the time wasn't updating on my phones. But a few seconds after placing a call to or from the phone, the time would update. I don't think this is a DST issue at all.
akascarface Fri, 02/16/2007 - 12:30
Did TAC acknowledge the bug and open a bug id for the CFwdALL issue. We are a heavy CFwdALL shop for our Road Warrior employees and your post has me very apprehensive about applying the patch until TAC acknowledges it and comes back with a revision. Thanks
MikeTomasko Fri, 02/16/2007 - 12:43
The TAC Engineer I worked with acknowledge that he would pass along the bug I ran into, but I wasn't given any bug number.
If you have any 7970's or 7971's you will want to watch going to 4.1(3)sr4d. Check out this post: http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddd91f7
I'm actually going to update to ES94 now because of that.
MikeTomasko Fri, 02/16/2007 - 16:25
I think the phone load included in 4.1(3)sr4d is 8.0.4. 8.0.5 is the latest.
MikeTomasko Fri, 02/16/2007 - 22:13
The 8.0.5 phone load is a seperate update. Only takes 30 seconds to install and doesn't need a reboot.
