PIX 501 client VPN
I use PIX 501 firewall and setup remote VPN aleady. but VPN client cant access intranet servers from outside. I want ask if intranet servers gateway address is not PIX intranet address is work? or all intranet server must need point to PIX intranet interface adddress ? e.g if PIX intranet interface address is 10.10.10.254 my intranet server gateway must 10.10.10.254 right ?
thomas.chen Thu, 02/15/2007 - 15:07
The default interface ip address can be PIX interface so that the packets can be forwarded to PIX gateway address.
kaachary Fri, 02/16/2007 - 05:49
Hi Alex,
There are two ways to achieve this:
1: Either you can point the default gateway for the Intranet servers to be PIX inside interface.
Or
2: You can add a static persistent route on the server for the vpn client pool, pointing to the PIX inside interface. E.G.
Client pool - 192.168.2.0/24
PIX Inside : 10.10.10.254
then add a route on the server as :
route add 192.168.2.0 mask 255.255.255.0 10.10.10.254
HTH,
-Kanishka
