Lines mixup
Feb 11th, 2007
I though it only happens in analogue but unfotunatly it happens in IP telephony world.
i have a 2811 router, whcih is Voice gateway, SRST, CUE and transcoder.
sometimes a problem happens when some one from an IP phone (internal) calls a person on the outside (PSTN), the IP phone do not hear anything and suddenly he is with a conversation with a guy who called in to the company and dialed another extension!!!!
it happened more than once, i have noticed a cpu usage between 30 to 50 average of the VG router.
any hints?
Good day
anderson-david Tue, 02/13/2007 - 02:06
can you post your config? It could be you do not have progress indicators configured on your dial peers ie
dial-peer voice 1 pots
translation-profile incoming potsincoming
destination-pattern 9[1-8].....
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
progress_ind disconnect enable 8
fax rate disable
direct-inward-dial
port 0/0/0:15
forward-digits 6
Dave
twissam Tue, 02/13/2007 - 02:32
Hi and thanks for your help, in fact i did a lot of installations and never had this problem and it is similar to the voice port below:
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone voice
input gain 3
output attenuation -3
non-linear mute
no vad
timeouts call-disconnect 5
timeouts wait-release 5
description Mobile Line
caller-id enable
voice class custom-cptone voice
dualtone busy
frequency 435
cadence 330 330
dualtone ringback
frequency 435
cadence 1180 4520
dualtone reorder
frequency 435
cadence 200 200
dualtone disconnect
frequency 435
cadence 200 200
Good day
