NVRAM config error message
Feb 11th, 2007
Hello guys,
I'm seeing this message when i do a show log on 3 of 5 2950 switches.
%SYS-4-CONFIG_NV_OVERRUN: Non config data present at the end of nvram is corrupted
I was wondering if there is something i should be concerned with?
I also checked the startup config and it looks fine according to company policies.
The version is: Version 12.1(13)EA1b, RELEASE SOFTWARE (fc1)
All 5 switches has the same IOS versions.
thx
Kim
ankbhasi Sun, 02/11/2007 - 12:47
Hi Kim,
Here is the description of the message you saw in the logs:
The software detected that the configuration saved into NVRAM has overlaid a part of the NVRAM occupied by nonconfiguration data files. Typically these files are used by SNMP to store and retrieve nonconfiguration persistent data acro ss system reload.
Recommended Action: Compress the configuration and store or copy to Flash memory, as appropriate.
To compress startup configuration files, use the 'service compress-config' global configuration command. To disable compression, use the no form of this command.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_system_message_guide_chapter09186a00801eb2e7.html
Ankur
*Pls rate all helpfull post
glen.grant Sun, 02/11/2007 - 16:00
Might try upgradeing to the latest code . Also if you are not using the browser management function you can safely delete the html directory out of nvram and this will free up a fair amount of space.
